accord transmission
Old Mar 16, 2014 | 09:05 PM
falente's Avatar
Default accord transmission
I have a 2012 accord 4cyl with auto transmission. When I shift the car from park to drive or park to reverse it has a hesitation before you feel it engage. It shifts okay when driving only this 2-3 second delay when putting into drive. Any ideas greatly appreciated
Old Mar 17, 2014 | 08:07 AM
I've had this symptom on my 94 EX for years w/o any adverse problems. I've heard it is related to low hydraulic pressure in trans slowing actuation of gears. Is this only a cold engine problem or all the time?
Suggest an ATF change; drain/replace. This helps many problems on Accords and is good practice. Some perform this regularly at 30K mile intervals.
Old Mar 17, 2014 | 04:03 PM
falente's Avatar
Thanks for the reply. I am off tomorrow so I think I will try changing the fluid. Good to hear it's a common issue. It has 186,000 miles and I don't have any records to tell if it was ever changed.
Old Mar 18, 2014 | 06:05 PM
Please, only use Honda trans fluid on this.
MessAround
Aug 13, 2011 09:45 AM
