Accord wont start
Old Jul 31, 2016 | 01:51 PM
madman1042002's Avatar
Default Accord wont start
I have a Accord 00 Ex v6 it was having trouble start in the heat.
i looked it up seen it was a common problem i changed the fuel pump relay, When i tried to turn it over it wouldnt start i checked the fuel pump it still works i hear it startup. now it just wont turn over, it wants to start just wont turn over im at witts end trying to fix this problem i need some help
Old Jul 31, 2016 | 05:09 PM
Install the old relay and see if the car will start up.
Old Aug 1, 2016 | 08:10 AM
tried that nothing happen. i also looked for cracks around the solder its was fairly good but i touched up a few place tried again and nothing still
Old Aug 1, 2016 | 12:06 PM
"Turning over" means the starter is spinning the engine. So if it's not turning over, you should be looking at the starter motor & wiring to the starter.
Tony1M
Nov 6, 2023 08:29 PM
jimmy3fingers
Oct 4, 2013 08:02 PM
gasface11
Jul 11, 2012 12:33 PM
MrGmo
Sep 28, 2007 01:40 AM
booter
May 11, 2005 02:26 AM
