Adjust the swing of windsheild wipers?
Old May 25, 2011 | 01:41 PM
jtimc7's Avatar
Default Adjust the swing of windsheild wipers?
Is there a way to adjust the arc that my windshield wipers make? They are tending to flop on the window edging at bottom part of the arc. If I could I'd like to shorten the arc they make to stop them from hitting the edge of the windshield.
Thanks!
Tim
2000 Accord
Old May 25, 2011 | 08:51 PM
bigdawg74's Avatar
Tim, I don't think the arc can be "shortened" so that the wipers move less degrees, but I do believe you can more or less change your wipers alignment. Remove the nut that holds the wiper arm. Pull the wiper arm off of the splined post, and replace it up a notch or two on the post. But watch that they don't go too far and hit the A-pillar. Hope this helps...
Old May 25, 2011 | 11:23 PM
00AccordLX5spd's Avatar
Registered User
I am curious about this as well. My 2000's wipers have started smacking HARD every time they hit the bottom of the arc. I just keep forgetting about it because it doesn't rain that much in Mississippi right now. If I figure anything out, I'll let you know
Old May 26, 2011 | 02:12 PM
jtimc7's Avatar
Yes, mine hit the bottom hard as well...
I'll try bigdawg's suggestion. Thanks!
muldavea
Oct 25, 2019 01:19 PM
chancestates
Nov 3, 2011 09:31 AM
darryltravis
Apr 26, 2006 01:14 AM
meazz1
Mar 24, 2006 04:22 AM
