Advice on 100K mile Services
Old Apr 1, 2025 | 02:43 PM
csherlock's Avatar
My 2014 Honda Accord V6 has about 85,000 miles on it, and it recently started making a knocking sound when it's cold. People on the forums suggest it could be a loose tensioner or idler. I've never had the belts replaced, though they were inspected last year, and the mechanic didn’t notice any significant wear. I did have the transmission fluid changed at 65,000 miles. From what I understand, the 100,000-mile service is mostly just inspections. As one person stated in the conversation, the 100K mile service is about $2K. This is the list of items I was given to have replaced. I was told that if your going to replace the tensioner then you just as well do the following.
A full timing belt kit service — make sure it includes:
  • Timing belt
  • Tensioner + idler pulleys
  • Water pump
  • Coolant
  • Drive belts
  • (Optionally) valve cover gaskets and cam seals if they need to come off
    Am I missing anything?
Old Apr 2, 2025 | 06:57 AM
ljbrew001's Avatar
Default Timing belt cost
Originally Posted by mbo1985
you NEED to do the timing belt serivce, including the water pump and seals. If that belt snaps, you won't be driving anywhere!
valve adjustment - use your judgement. If the motor seems noisy (clicking sounds) when warm, I would opt to do it. Otherwise you can live without it.
The timing belt job shouldn't set you back more than $500 and is vital to the life of your car. If you change it as schedualed, you can expect at least another 100K out of that car.
And just a reminder, keep that oil changed!
The Honda dealer near me wants $1400.00 to do the belt job on my V6. Maybe the four-cylinder is cheaper?
Old Apr 2, 2025 | 06:24 PM
That post is almost 20 years old, so prices were lower in 2006.
mihalis
Oct 11, 2011 05:00 PM
deserthonda
Jan 5, 2010 06:42 AM
KevinAccord
Jan 17, 2008 01:40 PM
Kai Winters
Dec 24, 2007 11:53 AM
nuprules
Mar 31, 2006 03:47 AM
