AF Sensor Signal Stuck??
Old May 27, 2007 | 06:47 PM
Dj Insanity's Avatar
Default AF Sensor Signal Stuck??
so i went to auto zone to get a free check up on a check engine light and it came out as a AF sensor Signal Stuch... does neone know what this problem may be? the guy said that ill prolly need to get 2 new o2 sensors.. neone else wanna add on to what he said or somtihng? THANKS!
Old May 27, 2007 | 06:53 PM
Chiovnidca's Avatar
Default RE: AF Sensor Signal Stuck??
Posting the trouble code will get you the most accurate help.
Old May 28, 2007 | 10:24 AM
hmmm... ok the code that auto zone got was P2195...
Old May 29, 2007 | 05:24 PM
anyone know what that code might be??
Old May 29, 2007 | 05:49 PM
hondadude's Avatar
ORIGINAL: Dj Insanity
I know, I know
"O2 sensor signal stuck lean" generic code
The computer expects to see the voltage swing on the primary sensor, and when it doesn't everswing above .5 volts the ECU has a hissy fit and throws a code.
I would first check the connections to the sensor. Next is to watch the voltagereading with a scan tool or meter.
Old May 29, 2007 | 06:46 PM
sir_nasty's Avatar
Someone else had that same problem and it turned out to be some oil in the connection.... so like Hondadude said make sure that your connections are tight and clean on your O2 sensor (located on your exhaust manifold)
Old May 29, 2007 | 11:10 PM
Thank you guys Probably will check that tomorow!!!
Old May 30, 2007 | 05:05 PM
Chiovnidca's Avatar
There's a service bulletin on that. The ecu needs a software update.
pondrun
Nov 8, 2021 09:40 AM
JollyGreenMini
Sep 18, 2010 09:29 PM
dineromike1
May 26, 2010 10:57 AM
HORSEPOWERJUNKIE2007
Mar 31, 2008 04:53 PM
kysit
Nov 25, 2007 05:44 PM
