Air bag code 61
Old Jul 27, 2012 | 07:42 PM
jfman55's Avatar
Default Air bag code 61
I have a 2004 Honda accord coupe v6 6 speed manual. I have air bag code 61 which by what I saw on vehix411 I believe the site is means internal failure. Any idea how that would be fixed. If not something I can do at least I know what to expect if I bring it somewhere
Thanks for any help
Old Jul 27, 2012 | 08:53 PM
How was this code retrieve? On the later Accords, they had different codes than the earlier Accords and also differed slightly depending on who made the SRS unit (e.g., TRW or Denso).
It might be code 61-1x ("x" can be 0 thru 9 or A thru F); open in driver's seat belt buckle switch. If it is the seat belt buckle switch, you may possibly be able to get Honda to replace for no charge.
There is no SRS code 6-1 for your year Accord.
Old Jul 27, 2012 | 09:07 PM
jfman55's Avatar
I jumped pins 4 and 9 on the obd2 connector. Airbag light had 6 long blinks and then 1 short blink. I also have an appt with honda on tuesday. But any info towards that?
Old Jul 28, 2012 | 09:15 AM
Others have fixed seat belt switch w/ liberal dose of WD40 and excercise by inserting/removing the belt into latch. However, as RB points out, Honda will likely cover cost of this problem and it's an easy fix.
Old Jul 29, 2012 | 11:34 AM
jfman55's Avatar
ok thanks so much. i have an appt with honda on tuesday and ill let you know what happens.
Old Jul 31, 2012 | 06:02 PM
jfman55's Avatar
Went to the dealer and its the buckle like you guys said and its covered. They had to order it but ill be done free of charge. Thanks
timgeorgi
Feb 3, 2008 12:09 PM
faxtell
May 10, 2007 12:40 PM
Luke SA
Nov 4, 2006 10:23 AM
adbraz
Jun 1, 2005 12:46 AM
adbraz
May 31, 2005 12:03 AM
