Air Conditioner Compressor not receiving power
Hi all, new to the forum and have searched and been unable to find a definitive answer.
AC only blows hot air. The system is charged, relays and fuses are fine. According to my mechanic, the AC compressor isn't getting power.
I have done some research and it appears that it COULD be the Climate Control Unit? Before I order a new one and go through the process of installing it, is there anything else it could be?
I am trying to avoid the Dealer if I can.
Thank You!
Thank You!
Describe your Accord in your signature line.
Are you willing to perform some diagnostics?
Check the wire to the compressor for 12V when AC is commanded On. I don't trust 2nd-hand info and there are reaons why it might not run w/ power available.
Does AC switch light come on when pressed to On?
jeremiah6120
Apr 16, 2006 03:32 AM
