Air control switches not working
Old Nov 30, 2008 | 10:42 AM
crazydad's Avatar
Default Air control switches not working
I have a 2000 LX 4 cyl that has developed aproblem with the controls for theair control and/or A/C. When cold, Ihit any of the switches and they light for a brief second, thengo out. This happens when the car is cold. If I run the car for 10 or so minutes, it usually begins working.There have been instances, though, that even when I'm driving it has cut out and there will be no green lights atall on the controls. The fan is usually set to the 1 or 2 position.
An ideas? Do I need to remove the controls and check the connections in the back? Can someone point meto instructions on how to do that?
Thanks, Steve
Old Dec 4, 2008 | 12:56 PM
Velocifero's Avatar
Default RE: Air control switches not working
ORIGINAL: crazydad
Thanks, Steve
Could be. I'd try that first, then if you can look at the bulbs. Good luck.
dasn25
Jul 16, 2013 04:42 PM
rescueswimmer
Jun 5, 2007 08:28 PM
EXV6
May 8, 2007 09:30 PM
joeeeee
Jul 8, 2006 02:17 PM
johnc
Mar 6, 2006 05:14 PM
