Airbag codes
Old Feb 26, 2024 | 08:20 AM
Bansheetaz's Avatar
Default Airbag codes
folks I've attached a list of codes from an 04 accord 4cyl. Airbag light is on. Is there any way to clear these or reset the module? If so with what tool? Or are the codes permanent due to an event? The airbag is intact and the seat belt is working normally. He seat belt indicator also goes on and off with the seat belt clipped in. Can I just swap the module? Do they have to be programmed to the vehicle or plug and play.
Thanks for any advice
Old Feb 26, 2024 | 11:18 AM
The seatbelt buckle recepticle has a switch inside to allow that module to know the seatbelt is buckled. This could easily be a problem with that switch or possibly the electrical connector. I'd try cleaning that component with electrical contact cleaner. See the video below.
yellowhammer2
Oct 12, 2019 02:05 PM
snowman24
Nov 18, 2018 09:10 AM
Jpat1957
Sep 22, 2016 08:53 PM
enemogomio
Feb 21, 2011 09:48 PM
pashwin
Nov 22, 2009 10:07 PM
