Alarm help
Old Jun 15, 2020 | 07:12 PM
Pepsiman952's Avatar
Default Alarm help
Ok...son locked his keys in his car, 03 accord exl 2 door coupe, and I got in thru the passenger side window with a coat hanger. Alarm goes off. Car was starting fine but could not reset the alarm because his drivers side door lock is broken and has no fob. No passenger side key lock. I messed with the hood latch wires, and pulled the instrument cluster out hoping to figure it out. Now the car turns over but won’t start. So question is, how do I reset/disable the factory alarm without the key/ door locks, and any suggestions as to why all of a sudden it stopped starting? Thanks in advance.
Old Jun 15, 2020 | 08:36 PM
Seanjordan20's Avatar
You need an original key with fob made to turn the alarm off. You should still be able to start the car with the valet key though.
I had a friend with an 03 and the alarm would not reset. The lights flashed every so often (he unplugged the horn). He was still able to start the car. He went and got an original key made with fob and everything worked good after.
DannyJdm
Jun 30, 2012 10:43 PM
rocketkidd777
Dec 28, 2011 05:34 PM
ram2miller
Jul 21, 2008 05:25 AM
guster900
Sep 15, 2006 07:55 PM
guster900
Sep 15, 2006 11:16 AM
