alignement ? 1992 accord
Old Jan 28, 2008 | 12:58 PM
tony11's Avatar
Default alignement ? 1992 accord
Hi, i have a 1992 accord 4 dr LX auto 2.2L.
Good tires, but have noticed a buzzing coming from the frt driver side tire.
This tire is showing wear on the inside tread area only- so maybe it threw a weight
I've got lifetime balance and rotation so I rotate/balance every 5-6k miles for free.
I'm thinking the alignment may be off, but will bring it in to the shop for a balance rotate job to see if that helps.
If they tell me I need an alignment, does this have adjustable front and rear (4 wheel) or is it only possible to do a frt wheel alignment?
What parts are able to be adjusted,camber , toe and caster?
Not sure so thought I'd ask b4 getting told what I need and not always trusting of these guys..
Thanks
Old Jan 28, 2008 | 09:03 PM
Default RE: alignement ? 1992 accord
I had the CV axle dynamic dampner come loose and cause a vibration. I managed to grind it off w/ an air-drived die grinder.
Old Jan 30, 2008 | 07:47 PM
drummer1279's Avatar
if only the outside of your tire has wear then chances are your alignment is out.. on front wheel drive cars most shops will do a 4-wheel alignment but if your rear end is ok you can just have the front end done. they will make sure that it all is good camber, castor, toe, etc..
thunder_x
Jan 26, 2009 01:11 PM
me2005
Jun 12, 2005 01:42 AM
Panther1224
May 12, 2005 10:42 PM
j
Mar 17, 2005 11:08 PM
ElectricTwilight
Jan 24, 2005 01:44 PM
