Altenator 4-wire Connector
Old Sep 15, 2007 | 08:31 PM
Default Altenator 4-wire Connector
I need a replacement 4-wire electrical connector to the alternator on my 97 Acura TL. Latch is damaged and connector gradually comes loose w/ vibration.
In looking at Honda/Acura replacement parts it appears the only way to get that connector is to replace the entire wiring harness. Anyone have a better idea. Salvage yards may help, but I've had problems on small items like this.
thanks
Old Sep 15, 2007 | 09:38 PM
Default RE: Altenator 4-wire Connector
Tough one.
Junkyard or Ebay would be my first thought. Maybe a place that rebuilds alternators would be able to order the plastic part.
Another option is to search Ebay for your engine. There are some Ebay stores that import low mileage engines from Japan, and it looks like from the pictures that they simply cut most of the wiring to remove the engine. You might have some luck by calling one of theses places to see if they have your connector just hanging on an engine.
Old Sep 16, 2007 | 01:52 AM
rtmobile96's Avatar
I'm not sure about this exact connector, butI know if your careful, you can take some of the connectors apart and pull the wires out. Their usually held together by smalltabs that click into place.You just have to make sure that you put the wires back in the right spot. If you can take that specific connector apart, I'd check a junk yard. I was able to do this with the connector for my V-tec silonoid.
Old Sep 16, 2007 | 06:56 AM
Thanks, today I'll try to rig a tensioned retainer w/ twisted wire and hopefully secure till I can find a replacement connector.
The tip to contact an alternator/starter shop to see what they suggest is a good one also.
I think I can ultimately get a part from a salvage yard, but it will probably take a lot of calls and visits to find one.
thanks
basket_case
May 10, 2015 06:06 PM
townsend13
Nov 29, 2013 06:22 PM
rao_manoj2004
Apr 14, 2013 07:30 PM
cxjon
Aug 24, 2008 01:51 PM
eazyazamp
May 17, 2007 12:51 PM
