Sponsored by:
Sponsored by:
Alternator
Old 03-19-2013, 11:58 PM
marcus88's Avatar
Default Alternator
Bought this 2000 Accord V6 with a recent engine change.... car starts & runs but alternator is not charging... we have checked all connections & fuses but no luck... dash lights on (battery light, light saying all 4 doors are open, truck open & brake light) when pressing the accelerator the warning lights on the dash start to flicker around 2500 rpm then around 2700 rpm the lights on the dash go out as if the charging system is operating... any suggestions???
Old 03-20-2013, 07:35 AM
Get the alternator tested. It might not be charging at lower RPM because of worn brushes or something easy to fix.
Old 03-20-2013, 12:34 PM
marcus88's Avatar
ok thanks, i will try the alternator & let u know the results...
Old 03-20-2013, 07:38 PM
marcus88's Avatar
new alternator same issue...
Old 03-22-2013, 11:46 AM
Is the CEL on? Even if not have it checked for codes.
Do you have a volt meter to do some tests?
Old 03-22-2013, 01:50 PM
firefighter44's Avatar
Almost A Senior Member
I know this sounds dumb but check the belt tension as belt slip could happen at lower rpms and cause no charging.
Also (ive said it before and will say it again) Check all your grounds! A bad/loose/corroded ground will reek havoc on a system and cause all kinds of strange issues.
aking
04-04-2011 11:19 AM
evilundoer
08-08-2006 07:18 AM
trvlnut
07-27-2006 02:57 AM
KerryG
07-26-2006 12:51 AM
CJH
07-13-2006 03:57 PM
Quick Reply: Alternator
