Another Newbie with another problem
Old Oct 25, 2010 | 05:42 PM
HondaAccordKid's Avatar
Default Another Newbie with another problem
I have a 1994 Honda Accord Ex and 2 days ago I was driving and right as soon as I shifted gears into second the pedal hits the floor and didn't come back up. I checked the reservoir and discovered it was empty. I put more fluid in the reservoir and pumped the clutch a few times and had no luck. I was hoping someone could explain to me how to bleed clutch because I'm having trouble finding how to do it elsewhere.
Thanks,
AccordKid
Old Oct 25, 2010 | 05:59 PM
g22cd5's Avatar
Supper Moderator
welcome enjoy your stay...try search around the DIY area for
Deserthonda’s how to thread on clutch master slave cynders. I think you have to go half way down the page for the info you need.
Old Oct 25, 2010 | 06:00 PM
Thanks alot man and GO GATORS!
Old Oct 25, 2010 | 06:02 PM
g22cd5's Avatar
Supper Moderator
Go gators!
Old Oct 28, 2010 | 11:32 AM
Hi Member..
I was the one who moved you to the correct thread for an answer..
I hope this will help you with your problem...
HI
to bleed the clutch master .. well take two people one to push and hold the clutch down while the other loosens the line going to the slave cylinder letting out some fluid, make sure they hold the clutch pedal down until you tighten the line back up or you will draw air in if they let the clutch back up before you got it tight. Do this a couple of time or until you get a good stream of fluid, check fluid level often.
The slave cylinder down at the clutch can be bleed as well. there is a little bleeder on it do the same as you did with master.
You may need to replace the master or the slave cylinder if they were fine and all of a sudden not working right.. as air just doesn't get in there.
40+ years experience
on1accord
Nov 24, 2010 09:01 PM
Aman1
Dec 21, 2008 03:47 PM
Aman1
Dec 20, 2008 07:29 AM
noalibi
Aug 12, 2008 05:28 PM
Tonyride
Mar 1, 2005 09:23 AM
