Newbie, with typical newbie question
Old Dec 19, 2008 | 09:41 PM
Aman1
Default Newbie, with typical newbie question
new here, 16 year old car lover. Just picked up a 2003 Honda Accord I-4 EX-L with 152kms for $9500 CAD. loving every moment of it so far. I just have a quick question: how often are the timing belts and water pumps supposed to be changed?
Old Dec 19, 2008 | 10:30 PM
finch13's Avatar
Default RE: Newbie, with typical newbie question
Your K-series has a chain. Water pump, not so sure.
Old Dec 20, 2008 | 07:29 AM
Hello New Member:
Welcome to the forums..
Your 1st post was in the wrong forum and I moved you over to this one...Make sure you read your forum rules...
[IMG]local://upfiles/22/4346EE36AB1540A89C37AFC5B324A134.jpg[/IMG]
Old Dec 20, 2008 | 03:25 PM
mpanelli's Avatar
I believe that Honda recommends changing it at 90k. That being said I feel safer changing it around 75-80k or 6 years which ever comes first. I would also suggest that you change the water pump at the same time since it is easily removed once the belt os off.
Old Dec 21, 2008 | 03:47 PM
2003 4-cyl has a timing chain, not a belt. Not replaced on any schedule of milage. Theres a spec on the position of the chain tensioner, but I dont remember the details right now.
The K-serieswaterpump can be replaced easily, since its driven by the external serpentine belt. Its located on the front of the block, it even looks fairly easy to remove.
Silverfox302
Jul 31, 2011 08:11 PM
on1accord
Nov 24, 2010 09:01 PM
PhillyTurboSix
Oct 29, 2009 02:54 AM
Aman1
Dec 20, 2008 07:29 AM
CivicEX
Oct 9, 2007 11:06 PM
