Sponsored by:
Sponsored by:
Newbie, with typical newbie question
Old 12-19-2008, 09:41 PM
Aman1
Default Newbie, with typical newbie question
new here, 16 year old car lover. Just picked up a 2003 Honda Accord I-4 EX-L with 152kms for $9500 CAD. loving every moment of it so far. I just have a quick question: how often are the timing belts and water pumps supposed to be changed?
Old 12-19-2008, 10:30 PM
finch13's Avatar
Default RE: Newbie, with typical newbie question
Your K-series has a chain. Water pump, not so sure.
Old 12-20-2008, 07:29 AM
Hello New Member:
Welcome to the forums..
Your 1st post was in the wrong forum and I moved you over to this one...Make sure you read your forum rules...
[IMG]local://upfiles/22/4346EE36AB1540A89C37AFC5B324A134.jpg[/IMG]
Old 12-20-2008, 03:25 PM
mpanelli's Avatar
I believe that Honda recommends changing it at 90k. That being said I feel safer changing it around 75-80k or 6 years which ever comes first. I would also suggest that you change the water pump at the same time since it is easily removed once the belt os off.
Old 12-21-2008, 03:47 PM
2003 4-cyl has a timing chain, not a belt. Not replaced on any schedule of milage. Theres a spec on the position of the chain tensioner, but I dont remember the details right now.
The K-serieswaterpump can be replaced easily, since its driven by the external serpentine belt. Its located on the front of the block, it even looks fairly easy to remove.
Silverfox302
07-31-2011 08:11 PM
on1accord
11-24-2010 09:01 PM
PhillyTurboSix
10-29-2009 02:54 AM
Aman1
12-20-2008 07:29 AM
CivicEX
10-09-2007 11:06 PM
Quick Reply: Newbie, with typical newbie question
