another turn signal question
Old Mar 20, 2006 | 12:37 PM
HAcc407's Avatar
Default another turn signal question
Where could I get a new bulb socket? You know the part that you plug the actual bulb into? I need a new one, and I'd assume i could get this at the dealer or at a junk yard, just wanted to check and make sure before I waste gas. Thanks for the help guys.
Old Mar 20, 2006 | 01:13 PM
sir_nasty's Avatar
Default RE: another turn signal question
I don't know if a dealer would have it but I'm sure a junk yard would... I believe I've seen these in like NAPA/Checker before as well... fairly cheep part. I'd call the parts store and get the cost... it may be like $10.00 and be more worth it just to pickup a new one.
Old Mar 21, 2006 | 12:34 AM
HAcc407's Avatar
ORIGINAL: sir_nasty
is the part I described the actual turn signal relay?
Old Mar 21, 2006 | 08:01 PM
sir_nasty's Avatar
No, the turn signal relay is inside the car.... that's actually what makes the "click, clack" noise you here when your signal is on.... I'm assuming you're talking about the part that holds your headlight bulb and provides the electrical contacts.
Old Mar 22, 2006 | 01:22 PM
HAcc407's Avatar
yeah that's what I'm talking about, the part that actually holds the bulb...I just thought I'd kill two birds with one stone and find out what the relay actually is. Thanks for the help tho
Old Mar 22, 2006 | 01:25 PM
sir_nasty's Avatar
Let us know if you have any issues finding that stuff... Good luck!
silver03
Dec 27, 2007 07:31 PM
HAcc407
Mar 7, 2006 09:43 AM
aghigig
Nov 20, 2005 03:04 AM
jcvlz
Aug 24, 2005 11:34 AM
mega502
Mar 19, 2005 12:30 PM
