Antenna Help
Old Nov 12, 2006 | 08:01 PM
ArcticHonda's Avatar
Default Antenna Help
Ok, so my antenna won't retract all the way down...I know there is a good write-up in the DIY section but can anyone tell me why these things don't retract? In other words, can you just disassemble the antenna and rebuild it or do you literally have to replace parts? If parts need to be replaced is it usually the mast or the motor?
Old Nov 12, 2006 | 08:05 PM
YeuEmMaiMai's Avatar
Default RE: Antenna Help
you need to lube it up with some machine oil
Old Nov 12, 2006 | 08:52 PM
deserthonda's Avatar
most likely the antenna mast is broken,,,,,,,,,,,,,,does it make a racheting noise??
Old Nov 12, 2006 | 09:26 PM
hondadude's Avatar
Follow thru this link to the part about cleaning out the drive gear and turning the tension pin 180 degrees.
Antenna Page
Old Nov 12, 2006 | 10:07 PM
It definitely makes a ratcheting sound...when there is about 3 inches left for it to retract. Sometimes it fully retracts in warmer weather. Also, I've read that antenna link but I first need to know whats broken so I can order parts if necessary.
Old Jan 25, 2007 | 06:51 PM
ORIGINAL: ArcticHonda
I just removed the antenna/motor by using HondaDudes DIY http://members.troublecodes.net/hond...-97antenna.htm . All i did was rebuild the motor and clean out all the teeth...good as new. The only thing I did different was I pulled the antenna in through the trunk along with the motor instead of disconnecting it and pulling it through the top.
Old Mar 26, 2008 | 01:26 AM
Stoenr's Avatar
Alot of thise links for member.troublecodes are dead now.
Search funtion is failing me, lol.
ScarletsAccord
Feb 11, 2011 04:13 PM
mamtsberg
Mar 17, 2010 09:15 PM
t12355
Apr 22, 2008 12:42 PM
Burnzy
Jul 17, 2006 01:20 PM
pgopalak
Dec 17, 2004 03:30 PM
