ANTI-LOCK LIGHT
Old May 12, 2006 | 10:58 PM
xxatsayxx
Default ANTI-LOCK LIGHT
I have a 1991 Honda Accord SE and the anti-lock light always comes on about a minute into the drive. Just wanted to know what can be done or checked to fix this problem
thnx
Old May 12, 2006 | 11:38 PM
Chiovnidca's Avatar
Default RE: ANTI-LOCK LIGHT
ORIGINAL: xxatsayxx
thnx
The abs light? What trouble code does it have stored?
Old May 13, 2006 | 12:48 AM
RTexasF's Avatar
Super Member
Please define "anti lock light". Is it the ABS light which chio asked?
Old May 13, 2006 | 12:59 AM
deserthonda's Avatar
as mentioned you need to let us know if there is a code ...
here is what you do,, put ignition key on,, go to the back of the car , the ABS control unit is located inside the trunk , passanger side..
there is a little plug you need to remove , so you can read the code..you might have to pry back on the inner liner ,,,,count the blinking frequency ,,,
it will be something like 4 flashes, little pause 2 flashes that's code 4-2...make sure to read it a ferw times , to properly read the code and to make sure there are not multiple codes .........post the codes here once read and we will go from there....
Also ,,,make sure the reservoir has planty of fluid..
Old May 13, 2006 | 02:11 AM
xxatsayxx
well after turning the key in the ignition to on i checked in the trunk for the red flashes. yet it just yields three flashes with short pauses in between and nothing after that wat does this mean??
Old May 13, 2006 | 02:40 AM
mmmm there is just no code 3 ,, there is MAIN code 3 , SUB CODE 1. 2 AND 4 ,, like ... there is 3-1 rt frt ,, 3-2 . lft frt . 3-4 ,, both rears ,,,these problems relate to wheel pulsors,,,pulsor is the ring that is in the axle ..... ..By the way have you replace an axle lately ???
i hate to say this but you might have to read the code again..,,and chk to see if there is a smaller blink after the short pause ..
Old May 13, 2006 | 02:56 AM
xxatsayxx
well we have had the CV boot changed and i think that is the closest to the axle... and i will check up on the code tomorrow. thnx
Old May 13, 2006 | 03:03 AM
did problem start after , soon after you had the cv boot replaced ???
Old May 13, 2006 | 03:28 AM
xxatsayxx
as a matter of fact it did...
Old May 14, 2006 | 04:11 AM
xxatsayxx
so the problem did occur shortly after the cv boots were replaced...
