anybody ever heard of this happening?
Old Apr 29, 2006 | 01:31 PM
LaminatedKitten's Avatar
Default anybody ever heard of this happening?
I just replaced the halfshafts on my car not much over 3 weeks ago, and as i'm driving up the road, damn car won't keep movin. So i take a look and the right halfshaft came loose! Any ideas on how or why that could have happened? its a 92 accord EX btw
Old Apr 29, 2006 | 01:49 PM
deserthonda's Avatar
Default RE: anybody ever heard of this happening?
ORIGINAL: LaminatedKitten
either you got the wrong axle ,, or whomever installed it did not do a proper job ,,
I would remove the shaft , get a different 1 , it is still under warranty ,, and make sure that it is installed correctly, ( snaps all the way into the tranny, axle nut tight, etc etc )
Old Apr 29, 2006 | 02:10 PM
i read somewhere else that there's different axles for ABS and non-ABS cars, would that have any difference besides the function of ABS system? and how do i fix this issue?
Old Apr 29, 2006 | 02:45 PM
,, the only thing that would happen if you install a NON-ABS axle into a car that has ABS is the the ABS lite would come on, because the ABS wheel sensor would not work,,
you can install a ABS axle into a NON-ABS car
you cannot interchange an auto tranny for 5 spd axle,, right side for left side ,, some cars have the short left shaft ,, the axle looks the same, same lenght , but the splines where it goes into the tranny are totally different ..
just make sure you get the right axle and it gets snapped properly into the tranny .
Old Apr 29, 2006 | 02:48 PM
i had it snapped and locked in, i heard and felt the SNAP of that ring locking it in, that's just weird how it kinda came apart...
Old Apr 30, 2006 | 03:20 PM
sounds like it went in ok,,and all the way in,,,, I would try a different axle ,,
Old Apr 30, 2006 | 06:30 PM
Where did you get that axel and what was the stock number on it...also ABS or No Abs...
Automatic or Stick shift?
WheelBrokerAng[sm=americanasmiley.gif]
y9pema
Nov 11, 2007 01:42 PM
Boogy
Mar 5, 2007 02:16 AM
junyea
Dec 19, 2006 06:58 PM
Goldnknight22
Aug 14, 2006 12:40 PM
93Accord10thYear
Jul 7, 2006 04:38 AM
