Anyone ever put a helicoil insert on cylinder head?
Old Jun 3, 2007 | 11:56 PM
Drpepper's Avatar
Default Anyone ever put a helicoil insert on cylinder head?
I just stripped the threads on one of the mounting bolt inserts while attaching the rocker cover to the heads of my 94 EX VTEC engine. Has anyone had to install a helicoil insert and what size do I need? Is that something AutoZone will carry?
Old Jun 4, 2007 | 11:17 AM
Default RE: Anyone ever put a helicoil insert on cylinder head?
I've used them in similar places. Carefully check out the hole before you drill it out. Make sure there's enough material surrounding the hole, so the action of enlarging it doesn't remove too much metal.
AutoZone probably; if not, call around. There's also a competing product called 'TimeSert'.
hondamthead
Mar 6, 2013 06:02 PM
Wicked Pete
Jul 3, 2010 09:30 AM
82009_honda
Nov 26, 2009 09:17 AM
getkickin
Apr 5, 2009 07:39 PM
SilverBullet
Sep 27, 2005 01:26 AM
