auto trans shakes at idol and shifts hard 92 accord
Old May 19, 2011 | 12:22 AM
vincentgould's Avatar
Default auto trans shakes at idol and shifts hard 92 accord
Can anyone discuss this issue with me? Is it common? my milage is only about 18 right now just bought the car and I am working all the bugs out.
Old May 19, 2011 | 01:22 AM
Exclamation Hi New Member
This needs to be in the Genl Tech forum so I will move it there..Read before you post so you get answers..
Old May 19, 2011 | 09:04 AM
Read what? Where is my post?
Old May 19, 2011 | 07:31 PM
Rules and that....should be a "sticky" at the top covering a few rules and that. One being, PLEASE add your car info to your signature so it can always been seen...just like now, I have to pause and scoll up to remember what year you have....I have short term memory issues.
Kind of tricky, you just got the car....idle could be a number of things. Start with the regular stuff first....tune up (cap, rotor, plugs, test wires, clean tb, check air filter, ect) , then check motor mounts to be sure one isn't broken.
After that, is this only cold/hot or at anytime? Only when cooling fans or ac is on?
For the shifting. Change, check the trans fluid. Then inspect/adjust the throttle control cable....of course a bad mount could also cause this.
Old May 20, 2011 | 08:34 AM
Thanks. What is clean TB?Motor mounts good. It gets worse when all components are on including AC. It happens hot and cold. Will a Trans fluid change cause more problems than help? Probably been a while on that one. Thanks for your help
92 accord 4 dr
Old May 20, 2011 | 08:47 AM
Tek310's Avatar
that is your motor mounts man.
more strain on engine + worn motor mounts = more vibration
get them checked at a shop. more so the front and rear mount that hold the most weight.
Old May 20, 2011 | 10:00 AM
Forgive me, man... so clean TB is my motor mount, sorry I still don't quite get that, is there a way to d=check this without a shop?
Old May 20, 2011 | 12:17 PM
bigdawg74's Avatar
I believe TEK310 was responding to your post describing the vibrations. Clean TB means clean Throttle Body.
Gopal
Nov 10, 2013 05:55 AM
94accordtn
May 7, 2013 01:25 AM
94exsedan35094
Oct 19, 2009 01:58 PM
stringsmjm
Mar 16, 2008 08:51 PM
jose310
Mar 15, 2008 12:07 AM
