AUX iPhone connection stopped working
Old Mar 11, 2015 | 10:53 AM
jesseberger's Avatar
Default AUX iPhone connection stopped working
Since I've had my car, I have been able to play music by plugging my iPhone through the phone's lightning connection into the car's USB port. It's worked well most of the time. Maybe one out of every 100 times I get a message that says "unsupported," but it goes away after unplugging and re-plugging the phone back in.
This morning, it completely stopped working. The message I get is "no song." Which I've never seen before.
Possibly a coincidence, but I just updated my phone to iOS 8.2 last night.
Help?
Old Mar 11, 2015 | 11:05 AM
Turtlehead's Avatar
It is likely the upgraded phone software. Confirm that the port works using someone else's phone or iPod before pursuing diagnostics of the car. Good luck and welcome to HAF.
Old Mar 11, 2015 | 11:32 AM
I will check that out. Thanks.
My fear is that it is the new iOS update. If that's true, what could I do? Will my Accord forever be incompatible with newer versions of iOS?
Old Mar 11, 2015 | 11:39 AM
Turtlehead's Avatar
If that is the case you may want to call your local dealer and find out if they have a software update they can run for the car. I am not familiar enough with the software updates they have but it is worth asking assuming the jack is fine. If they don't then an aftermarket radio would likely be the best choice.
Old Jun 28, 2022 | 02:39 AM
rsolis27's Avatar
Help?
I’ve had a similar issue, when trying to use the usb to play music through my iPhone, it just says “no data”. It used to work just fine but out of nowhere while playing music, it just cut out and said “no data” since then, it was never worked. I mean it’ll still charge my phone and my phone shows it’s connected via USB, but the car just displays “no data”. I have a 2015 Accord Ex-L with the dual screen
IronMike778
Apr 30, 2013 09:25 PM
Clutch34
Feb 9, 2009 10:44 AM
jrschmank
Jun 4, 2006 07:13 PM
jayallen40
Dec 4, 2005 10:46 PM
88COMMUTER
May 26, 2005 10:03 PM
