Bad Idle from accessories
Old Jan 28, 2008 | 11:05 PM
patpatpat's Avatar
Default Bad Idle from accessories
I have noticed that my idle goes way low when I even lower my power windows. Would this be a bad battery? bad alternator? bad ground?
It also happens when the radiator fans kick on.
Thanks
Old Jan 28, 2008 | 11:18 PM
nafango2's Avatar
Default RE: Bad Idle from accessories
i would check all three, but it sounds like a bad ground or alt to me. perhaps a battery cable is mostly pulled out of a crimp?
start the car, let it idle, and turn off all accesories. What is the voltage across the battery? were looking for about 14.5v
then turn on as much stuff as you can, rear window defroster, blower motor, etc etc. what is it now?
does it do the same if you turn on the A/C?
giulio76
Dec 29, 2012 11:16 AM
debby campbell
Jun 7, 2007 08:04 PM
arunsam3000
Mar 6, 2007 01:40 PM
projectaccord96
Apr 7, 2006 10:14 AM
