Balancer Belt Question
Old Oct 23, 2006 | 12:17 PM
MakoMan's Avatar
Default Balancer Belt Question
The honda factory manual shows a special tool, a pin with a threaded shoulder, that is used to hold one of the balancer shafts in place while replacing the balancer belt. It looks like an access bolt is removed from the back of the motor and this tool is threaded in and it catches a recess on the balancer shaft and holds it in place while replacing the belt. My question is, is this tool absolutely necessary to replace the belt, or is it one of those nice to have but not needed tools?
Old Oct 23, 2006 | 01:42 PM
deserthonda's Avatar
Default RE: Balancer Belt Question
the reason to put that tool on the back is to make sure that the rear balancer shaft does not spin and it will be out of alignment, you can use a regular punch...
what i do is to get a magic marker, have engine at top dead # 1 and before i remove any belts i mark everything, so i can reinstall it the same way .. so no need to even remove the rear bolt and install a punch
also, there are markings all over to show where trhe balancer shafts should be properly aligned..also one thing i di,, before i mark the shafts i make sure that they are aligned with the marks properly......especially if t-belt has been done once before,, you can never assume that the tech before you aligned everything properly ..
Old Oct 23, 2006 | 04:16 PM
MakoMan's Avatar
Thanks, that is the answer I was looking for. I'm doing a timing belt this weekend and don't wan't any surprises.
wendellanderson2009@hotmail.com
Jun 22, 2012 02:49 AM
TACORICAN
Jun 11, 2007 07:44 PM
RSM93HONDA
Jun 7, 2007 06:32 AM
quietgiant
Feb 10, 2007 12:26 AM
vdabis
May 9, 2006 07:30 PM
