battery connected backwards/reversed
Old Aug 7, 2007 | 03:13 PM
adnoh2
Default battery connected backwards/reversed
1990 accord... kids reversed battery cables tried to start and blew main fuse. After correction of battery terminals.. the car turns over but will not start..What else did they screw up? What do I need to check? I don't know alot about these cars but am pretty handy with a wrench. Thanks for your help in advance.
Thanks
Jeff......................................by the way, this is my first post !!
Old Aug 7, 2007 | 03:21 PM
sir_nasty's Avatar
Default RE: battery connected backwards/reversed
Check for spark and fuel. Let's find out which one you're missing. If you have an old spark plug just pop a wire off one of the plugs, place the plug in the wire and set it on top of the motor, turn it over and see if it sparks, as for fuel, when you first turn on the key listen for the fuel pump to pressurize.
Old Aug 7, 2007 | 04:11 PM
deserthonda's Avatar
chk the rest of the fuses ,, underhood and under dash before anything else
Old Aug 7, 2007 | 05:38 PM
adnoh2
Thanks guys for the fast replys ,will do all the above and post back. Where are the fuses under the hood? Are there more than just the fuse block?
johnrehder
Jan 28, 2017 06:08 PM
alpac
Apr 6, 2009 12:18 PM
benjamindavidbiggs
Dec 10, 2008 06:58 PM
mark28269
Sep 16, 2008 11:15 AM
caliprophet
Jan 3, 2007 02:11 PM
