battery corrosion
I'm having a problem with corrosion on my battery, and was wondering if anyone knows why it would be such an issue. I bought my car on December 22nd, and the positive battery terminal at the time was heavily corroded. On or about Jan 15th, I had an oil change done and asked the garage to clean the terminals, which they did and they also applied a corrosion inhibitor. Well, just a few weeks later and the terminal is corroded again. The only thing that I can think of is because I have 2 wires connected to the terminal that power my high intensity headlights. In fact, the corrosion was so bad a few weeks ago that one of those wired corroded right off.
Any thoughts?
Any thoughts?
Often what happens is the plastic case of the battery develops hairline cracks around the posts. That allows corrosive gas (& maybe sulfuric acid)to come out directly onto the terminals.
That battery wouldn't happen to be original, is it? Even if you got a new one at the 5 year mark, you are at the 10 yr mark now ..... might just be time for a 3rd 5 year battery.
ORIGINAL: JimBlake
Poor seals around the terminal post is the leading cause of green fuzz growth.
The only thing I'd try is layng a thick coat of heavy grease around the post seam; but not on the post. Grease does not conduct electricity.
Thanks guys! I'll take a closer look at the terminal today and also see if I can figure out when this puppy was put in. Since I just bought the car in December, I have no idea how old it is.
Can anyone recommend a good battery...a tow truck driver recently voiced his (negative) opinions about Sears, which is usually what I'd get.
I've had nothing but good results from Sears, but have heard the horror stories as well ..... I think a friend got one that was DOA, but it was replaced the next day. I like Sears' computer system. If you go down the list of what fits your car, there are alternates toward the bottom. My accord had a truck, SUV and Van battery that was the same size with a lot more CCA's for an extra 10 bucks.
