battery corrosion
Old Feb 5, 2008 | 11:59 AM
Avonlea22's Avatar
Default battery corrosion
I'm having a problem with corrosion on my battery, and was wondering if anyone knows why it would be such an issue. I bought my car on December 22nd, and the positive battery terminal at the time was heavily corroded. On or about Jan 15th, I had an oil change done and asked the garage to clean the terminals, which they did and they also applied a corrosion inhibitor. Well, just a few weeks later and the terminal is corroded again. The only thing that I can think of is because I have 2 wires connected to the terminal that power my high intensity headlights. In fact, the corrosion was so bad a few weeks ago that one of those wired corroded right off.
Any thoughts?
Old Feb 5, 2008 | 01:09 PM
00AccordLX5spd's Avatar
Registered User
Default RE: battery corrosion
Hmmm....probably just an old battery. Over time, they tend to corrode like that. Just my $0.02.
Old Feb 5, 2008 | 02:39 PM
Often what happens is the plastic case of the battery develops hairline cracks around the posts. That allows corrosive gas (& maybe sulfuric acid)to come out directly onto the terminals.
Old Feb 5, 2008 | 05:04 PM
falkore24's Avatar
That battery wouldn't happen to be original, is it? Even if you got a new one at the 5 year mark, you are at the 10 yr mark now ..... might just be time for a 3rd 5 year battery.
Old Feb 5, 2008 | 06:04 PM
hondadude's Avatar
ORIGINAL: JimBlake
We have a WINNER [sm=bounceybounce.gif] ......Give that man a cigar.
Poor seals around the terminal post is the leading cause of green fuzz growth.
The only thing I'd try is layng a thick coat of heavy grease around the post seam; but not on the post. Grease does not conduct electricity.
Old Feb 5, 2008 | 06:10 PM
SVTMike's Avatar
Here is what I do, everytime I check my oil I let a drop or two fall off the dipstick onto the terminal. DONT let the dipstick touch the terminal though.
Old Feb 5, 2008 | 09:57 PM
ORIGINAL: hondadude
Cough COUGH... HACK Ugghhh....
better make that a chocolate cigar.
[sm=yeahsmile.gif]
Old Feb 6, 2008 | 07:58 AM
Avonlea22's Avatar
Thanks guys! I'll take a closer look at the terminal today and also see if I can figure out when this puppy was put in. Since I just bought the car in December, I have no idea how old it is.
Can anyone recommend a good battery...a tow truck driver recently voiced his (negative) opinions about Sears, which is usually what I'd get.
Old Feb 6, 2008 | 08:32 AM
Registered User
Many will flame me for this, but I have always liked Duralast from AutoZone. They have a lifetime warranty. If they EVER fail, AutoZone will replace for free.
Old Feb 6, 2008 | 02:00 PM
falkore24's Avatar
I've had nothing but good results from Sears, but have heard the horror stories as well ..... I think a friend got one that was DOA, but it was replaced the next day. I like Sears' computer system. If you go down the list of what fits your car, there are alternates toward the bottom. My accord had a truck, SUV and Van battery that was the same size with a lot more CCA's for an extra 10 bucks.
