Battery dead
Old Jan 22, 2009 | 01:25 PM
abhijitgp's Avatar
Default Battery dead
Hello,
there are some loose connections in my car as every time I turn or car goes over bumps, the dome light and the door lights come on. It is annoying the way they keep flickering. Today, the car won't turn on and no functions work. Looks like the battery is dead. Is it possible that it was drained because of such loose connections ? I will jump start the car today, but how do I locate and fix the loose connections? Also what is the test to verify that battery was just drained and not about to die?
thanks in advance for any responses.
Cheers!
Old Jan 22, 2009 | 02:00 PM
Default RE: Battery dead
To see whether its on its last legs, test the battery under load. I could write some instructions, but places like AutoZone usually will test it for free.
Old Jan 22, 2009 | 05:03 PM
hondadude's Avatar
As far as the dome light and door lights flicker; you may need to adjust the door striker [hook on the door post]inwards about 1/4'.
It might be that the door not latching tight enough let the dome light turn on after you walked away from the car, hence the dead battery.
Old Feb 27, 2009 | 11:30 AM
abhijitgp's Avatar
Thank you all for the replies. Last week, I jumped the car and went to Autozone and had them check the car battery. It appears the battery was in the car since OCT 01. He said I was lucky it lasted this long... well, he changed the battery and the car was working fine. Now, I didnt use the car for past 4 days, but also did not take care of the door light. So when I tried to start the car this morning, the battery was dead again... well, rather too weak to crank the car. I am going to take the door light bulb out but is there any way to detect any other leaks in the car that may be draining the battery.
thanks
Old Feb 27, 2009 | 12:05 PM
deserthonda's Avatar
like the DUDE said,, fix the door first,, if problem is still there ,most likely there is an electrical drain in the system,, there is a write up on the DIY section to chk for electrical drains.. also make sure that alternator works properly
matttv
Aug 12, 2013 03:50 PM
Lenno
Jan 29, 2012 07:45 PM
ohill1981
Jun 16, 2011 11:48 PM
guugoo
May 30, 2011 06:44 PM
deserthonda
May 18, 2006 12:32 PM
