Battery drain issue
Old May 26, 2022 | 10:19 PM
AgonizedHonda's Avatar
Originally Posted by PAhonda
Passenger side fuse 11 feeds all the door courtesy lights, the spot/fog lights, trunk light, homelink (garage door opener), dome lights. I'll keep looking, as the 98-02 shop manual doesn't have a tree diagram for items downstream of the fuse.
Only thing I still have connected is the door lights, everything else isn’t connected and doesnt draw. My radio is also fried and pulls 12.5 volts at the deck wires.
Old May 27, 2022 | 03:12 PM
The voltage measurement is the wrong measurement for a parasitic battery draw. You can measure ~12V at any wire that is hot at all times, but that doesn't mean you are drawing current.
You need to hook up your volt meter in the amp setup where you disconnect a battery cable and hookup the meter between the battery post and a battery cable. I suggest you do this on the negative terminal. Your setup will have the wiring going through your volt meter. You want to keep contact through the volt meter when removing the negative terminal through your volt meter, so slightly lift up the negative terminal and have an alligator clip to connect to the battery post under terminal. Also have an alligator clip on the negative battery cable. Hope this makes sense. pinehollow diagnostics on youtube has some good videos on parasitic draws that should help.
Old May 27, 2022 | 07:08 PM
I got it. My radio was the draw. Running the tests you sent just confirmed it was my radio deck. Cheered mates, thanks for the help
honda.lioness
Mar 5, 2017 09:56 AM
Jason Allen Hines
Jun 7, 2013 08:34 AM
Steffyj862
Apr 3, 2013 09:05 PM
nickel11
Jun 19, 2010 12:22 PM
fortyfootelf
Feb 18, 2010 11:44 AM
