Battery Light
Old Nov 11, 2022 | 04:57 PM
vvaldez's Avatar
Default Battery Light
Hey guys, new to the forum! My apology in advance if this not the right place to post my Comments and/or Question.
I am experiencing similar situation but for different reason. My was one more victim of catalytic convertor theft, as you know is very common nowadays.
Shortly after the Battery light when on, Stop by Auto Zone to test the Battery and diagnostic said battery is good but the Alternator is bad. I replace it a new DENSO unit, but the Battery light remain on. I find that Honda has an ELD (electronic load detector) mounted in the fuse box under the hood,
That anybody experience similar Problem?
Any idea or suggestion?
Thank you.
Old Nov 11, 2022 | 05:59 PM
Moved your post to a new thread to make things less confusing.
Do you have a volt meter to test battery voltage with the engine off and with the engine running?
Old Nov 14, 2022 | 01:52 AM
vvaldez's Avatar
Yes, I check the Battery and 12.4 Volt and the Alternator is 14.5 and check all the fuses and they are ok, Battery terminal are clean and tight. I will post a picture later.
SO688
Jul 25, 2022 06:05 AM
HondaWhoDoToo
Apr 26, 2020 03:31 AM
PhillyAccord
Nov 19, 2018 05:35 PM
Panchin
Oct 30, 2014 11:04 AM
mschne2
Nov 13, 2013 05:22 PM
