2013 EX L "BATT" Warning Light Back on After Battery Replacement
Old Apr 1, 2018 | 09:13 AM
PhillyAccord's Avatar
Default 2013 EX L "BATT" Warning Light Back on After Battery Replacement
Greetings. I recently purchased my 2013 EX L with about 55k miles on it. The "BATT" Warning Light came on . I replaced the battery (at pep Boys) and everything's ok. Two weeks later, the "BATT" is back on.
Any suggestions on what the problem might be would be appreciated.
Old Apr 1, 2018 | 10:34 AM
Use a volt meter to test the battery voltage across the battery posts with the engine off. Then turn on the headlights and measure the voltage, still with the engine not running. Finally, test the battery voltage with the engine running. Let us know the 3 measurements.
Old Apr 1, 2018 | 11:56 AM
Test the battery like PAhonda recommended. If the battery is okay, then check to see if under-hood Fuse No. A5 (10A) is okay.
Old Apr 2, 2018 | 10:34 AM
rockhoundrob's Avatar
I thought anytime the "battery light" is on, the problem is actually the alternator.
Take it to a auto parts store and they should check your battery and alternator for free.
Old Apr 2, 2018 | 10:55 AM
Later generation Hondas have battery sensors.
Old Apr 19, 2018 | 06:23 PM
Default Update
Embarrassingly enough, it seems that the "BATT" light signals a low key fob battery. Replacing the key fob battery fixed the problem. Thanks all for your assistance.
Old Apr 20, 2018 | 11:54 AM
The Toecutter's Avatar
Well, that's a great reminder. You just have to remember that when it happens again.
Old Nov 19, 2018 | 04:01 PM
tferstl's Avatar
what's a key fob?
Old Nov 19, 2018 | 05:35 PM
The remote to lock/unlock your doors.
rah140
Feb 13, 2025 12:17 PM
matthewtorres2323
Mar 18, 2015 12:49 AM
gibber
Mar 7, 2013 07:06 AM
Ardenis
Oct 9, 2011 09:05 PM
tru3_k177
Feb 4, 2008 02:50 PM
