Battery Light
Old May 28, 2007 | 12:39 PM
justin89
Default Battery Light
every time i turn A/C on, my battery light comes on. I have a 91 acord EX
I changed batery connectors
All help is deeply apreciated
I need to pass inspection at the end of the month.
Old May 28, 2007 | 01:24 PM
Default RE: Battery Light
It probably means your alternator has a bad diode, which limits idle voltage output. When AC load is added, voltage is inadequate and bat light comes on. Fix is to have your alternator overhauled w/ new diodes, rectifier, and brushes, or purchasea rebuilt unit. I've always done this because some rebuilts are poor quality.
Old May 28, 2007 | 04:01 PM
justin89
ok, thank you
but its not just while idleing. is this important or will i use the same treatment
Old May 28, 2007 | 04:04 PM
You can confirm the problem by removing the alternator and having it tested at an auto electrical shop Autozone, et al also have alternator test rigs. I paid about $70 to have my alternator overhauled, rather than buy a rebuilt from AZ or O'R.
Old May 28, 2007 | 04:26 PM
justin89
thanks
schaicho24
Jan 1, 2014 09:10 PM
cadams8221218
Jul 15, 2011 07:24 AM
RoKnAzn
Jan 19, 2007 01:56 PM
Brian
Feb 2, 2006 08:04 PM
