Battery still Drains with New Alternator 91 Accord
Old Oct 9, 2011 | 08:14 AM
50gtconvertible's Avatar
Thumbs up Battery still Drains with New Alternator 91 Accord
I finally received the OEM Pulley on the 7th Oct and put it on the car. When i took off the old pulley it came off in 2 pieces.
The outer ring with the groves separated from the rubber. Now the car charges at 14.11 volts when idling so i guess that was my problem.
Now i have to fix a squeaky belt because i think it's on too tight.
Thanks for all your advice you have been a big help.
Old Oct 9, 2011 | 08:50 AM
Glad you got it....thanks for the update
Old Dec 20, 2011 | 11:39 AM
CRiSS's Avatar
i just started working on my brothers 93 lx,and he keeps loosing voltage.we removed the alt,and had it tested and it is fine,the battery is 2 weeks old,and when it is running the voltage drops and keeps dropping untill we shut off the car(we used a volt meter,and battery charger).now im looking for broken wires and fuses.any ideas.
Old Dec 20, 2011 | 07:28 PM
Besides some listed in the thread you posted in? I didn't re-read this but have you confirmed the pulley is not slipping...
any stored codes?
are the readings at the battery or the alt?
Old Dec 21, 2011 | 10:19 AM
CRiSS's Avatar
posted a thread,and i couldnt see it on my computer(not sure if it is because im a new member),so i reposted it in this old thread...all i did last night was upgrade the ground wires from 16 guage to 8,and i added some,and now it charges up from 11.60 with the lights on to 13.+,and with the lights off 11.40 to 13.+. im not sure this fixed the problem,but the car is old,and he also had radio power,and ign wires open sitting on the ashtray.again im not sure that that fixxed it,after work im goint to test drive it,and let it run at iddle a little longer...thanks for the help
gillman331
Mar 25, 2013 07:18 PM
thomis
Sep 20, 2012 09:40 AM
thomis
Sep 4, 2012 09:31 PM
1magiced
Jul 22, 2012 11:23 AM
shabha
May 22, 2011 06:22 AM
