beamerman 2005 accord
Old Jan 11, 2017 | 07:26 PM
beamerman's Avatar
Default beamerman 2005 accord
I have a 05 accord 6 cyl It acts like it is locked out but according to lights on dash, it is not. It does have a remote starter too. Symptoms are all lights work, turn key on and fuel pump cycles but starter totally dead when trying to start. Likewise when trying remote start, everything sounds like it cycles right until starter should kick in, but nothing. I have checked fuses, disconnected battery to reset computer, but no starter noise at all. Any possibilities for a fix that I haven't thought of?
Old Jan 12, 2017 | 09:51 AM
I moved your post for better attention. Welcome to HAF!
Suggest checking small b/w wire (solenoid drive) at starter for 12V start signal.
If present, the starter is toast and a new starter is fix.
If signal missing, then wiring, starter cur relay, trans range switch, or ignition switch.
Attached is start wiring diagram.
Old Jan 12, 2017 | 09:23 PM
beamerman's Avatar
Default 05 honda accord beamerman (Pete)
Thanks TexasHonda I will dig into it Sat morning and hopefully get it fixed. Printed off the wiring diagram. That will be a big help Thanks again Pete
faran
Aug 1, 2016 06:07 PM
pedalfaster
Apr 19, 2007 03:01 AM
lcc27
Mar 8, 2005 02:49 AM
GolfingTiger
Mar 7, 2005 06:02 PM
