Beater with Heater Part II
Old Oct 17, 2024 | 12:44 PM
Pampas56's Avatar
Default Beater with Heater Part II
Now that we have a handle on the ABS issue another issue has reared its head.
The turn signal/hi-lo switch quit working. left and right work, but it is stuck on low beams.
Can this be replaced without removing the steering wheel?
Thanks
Steve
Old Oct 17, 2024 | 01:32 PM
You'll have to remove just the plastic covers. That TRQ channel on YouTube also has a how to video on the combination switch.
Once removed, you can disassemble the switch to clean the internal contacts and relubricate with some dielectric grease if you want to try the very cheap route to fix.
Old Oct 21, 2024 | 04:32 PM
Pampas56's Avatar
I was able to pry the covers up and down to replace the switch. Never did figure out how to remove them completely.
IT ain't right but it worked!
Steve
tashier
Aug 24, 2015 01:43 PM
weannaun
Jan 18, 2013 05:14 PM
beagle
Sep 25, 2011 08:06 PM
Joseph
Jan 14, 2008 11:42 PM
xird77
Jun 26, 2006 01:05 PM
