Beep Codes
Old Sep 18, 2008 | 02:43 AM
BernardR
Default Beep Codes
We have a 91 Accord EX.
Recently it wont start, when the ignition switch is turned to the on position there are a series of 6 evenly spaced audible beeps; turning to the starter position the engine turns but does not fire. Several years ago I had a BMW which used audible beeps as an initial diagnostic and I assume that's the case here but I can't find any reference to them.
I tried looking at the diagnostic codes for the injection system. I located the blue diagnostic two pin plug and shorted it, but there is no check engine light on the instrument panel and no lamps flash when the ignition switch is turned on. I checked the ECU and found a LED that gave one flash when the ignition was turned on and another flash when it was turned off; shorting the maintenance plug made no difference to the LED flash.
Any help greatly appreciated.
Thanks,
BernardR
Old Sep 18, 2008 | 11:48 AM
finch13's Avatar
Default RE: Beep Codes
Honda doesn't use audible beeps for diagnostics, the sound is more likely the chime reminding you to buckle the seat belt. To me it sounds like you don't have any codes either.
europeanforums
Feb 6, 2008 10:42 PM
hawkeye
Jul 10, 2007 04:13 PM
kreizyidiot
May 25, 2007 11:19 AM
eckhart
Jun 29, 2006 07:02 PM
eckhart
May 8, 2006 01:05 PM
