beeping sound when braking
Old Jan 16, 2007 | 03:33 AM
sharapova4lyfe
Default beeping sound when braking
hi, this is my first post. i have a 2004 accord and when i brake, i hear a very soft beeping sound. when i start braking, it beeps around once a second and when the car is almost stopped, it gradually slows until there is no more beep. i can't hear this unless it's a very quiet place and my radio is off. is this beeping sound normal? thanks.
Old Jan 16, 2007 | 04:14 AM
Default RE: beeping sound when braking
Hard to tell without hearing firsthand. It might be the brake pad wear indicator tabs. If so, it'll get worse, like fingernails on chalkboard. Then you'll know to replace your brake pads.
Old Jan 19, 2007 | 01:20 AM
wietgr's Avatar
I would say that it is most likely brake related. Since you say that the noise slows as your vehicle slows it is make the noise for every revolution of the rotor. I would pull the wheels and see what the brake pads look like, make sure there is even wear between in-board and out-board pads. I have seen where a warped rotor will cause the caliper to move back and fourth on the slides. Use a runout gauge and check that the rotor is true.If it is not, then replace therotors andpads, be sure to lubbed the slides withanti-seize
Old Jan 19, 2007 | 11:45 AM
deserthonda's Avatar
most likely it is the pads wear bar letting you know that it is time for pads replacement ....pull thw wheels off and chk the brakes
Danrobert
Jul 29, 2012 11:03 PM
dgp1961
Dec 23, 2009 06:52 AM
Johnene
Aug 17, 2009 04:38 PM
jepoy3227
Mar 14, 2006 01:31 PM
greenwood
Jan 4, 2006 11:51 PM
