big brake kits
Old Feb 14, 2006 | 03:32 PM
flomasta's Avatar
Default big brake kits
Hey i'm in need of a big brake kit asap and don't have like 1300 $'s to work with. i was lookin at brembo but to damn expensive, and wilwood don't make any for my car, (1996 honda accord lx, 2dr coupe with disks up front and drums in back.) any good alternitives ?????????? thanks
Old Feb 14, 2006 | 04:07 PM
98accrd's Avatar
Default RE: big brake kits
Get the rear discs and necessary hardware from an ex 94-97.
Old Feb 14, 2006 | 05:30 PM
lightshow's Avatar
yea you dont need a big brake kit. and if you keep it stock you can put a spare on if you blow out a tire. just put drilled rotors front and back with good pads like EBC. you will stop real fast.
Old Feb 16, 2006 | 04:34 AM
EMEX's Avatar
ebay has this kit by a manufacturer, used to be called aem, now they changed the name on their brake parts to something else. you can search under '97 accord big break. pretty much what it is, is a 2 inch bigger front rotors with special adapters. they'll work with a stock calliper too. just make sure if you get it change the break pad to ceramic or better. the kit is about 400 bucks. my friend actually managed to find a tenzo one like that for 300, but i haven't seen any lately.
Old Feb 28, 2006 | 10:36 PM
flomasta's Avatar
okay i just need brakes bad so i thought i would buy a kit and be done with it, but now ima get slotted rotars and pads. still not sure on what brand though... What do you think about power slot rotars??
Old Mar 1, 2006 | 02:24 PM
sir_nasty's Avatar
Just a warning... Cermaic Pads don't grip for $#!^ until they reach a very high temperature, Not usually a good daily driver pad (if it's a true ceramic pad...), Other than that I'm not 100% sure on what to go with as far as brands but the suggestion of getting a brake setup from a different year with new rotars and pads sounds good to me.... My opinion on a big brake kit: If you are doing 25 mph with your stock brakes and you slam on the brakes do the tires lock up? If you're just doing daily driving then how are big brakes going to stop you more quickly? Locked up is locked up
Old Mar 1, 2006 | 02:28 PM
lightshow's Avatar
i would recommend drilled rotors i dont really like the slotted ones that i have on my TL. doesnt matter what brand as long as they are machined well.
Old Mar 1, 2006 | 03:32 PM
flomasta's Avatar
the only thing that worries me about drilled rotars is that i heard that they wear pads quicker and tend to need to be replaced more frequently.
Old Mar 1, 2006 | 03:53 PM
lightshow's Avatar
yea they do wear pads quicker. if you have a high performance system you should be worrying about pads though cause they only take about 30 min to change out. stopping distance is the main concern. stopping from 110+
Old Mar 1, 2006 | 10:31 PM
flomasta's Avatar
yeah it not that changing the pads is a hassle it's just the fact that i'm gunna have to do it more but, hey what can ya do??? o well. i guess il get real quick at doin it. haha THINKIN OF THE POSITIVE......
INOV8
Aug 22, 2011 01:10 PM
J30_tuner
Apr 30, 2009 03:40 AM
sUbLiMe96
Jul 16, 2008 10:52 PM
otsb708
Apr 1, 2007 09:56 PM
benjiaccord
Mar 22, 2007 01:26 AM
