Blinking Battery Light
I did some search and can't seem to find what is causing my 1990 Accord's battery light to do a short blink. Sometime just one short blink and other time 3 or 7 consective short blinks with about one second between each blink. Anyone have an idea what is causing it?
recent work:
-replaced and adjusted the throttle position sensor
-replaced VSS
-replaced Power Steering Pump
-replaced Alternator
Aside from hard shifting on the second and third gears, everything else seem to be running fine.
Thanks,
recent work:
-replaced VSS
Thanks,
The battery light means that the alternator or maybe battery are not providing enough voltage. You can get the battery/alternator checked at autozone.
I would make sure the the battery cable connections at all ends are secure and clean. Also check the alternator connections as well.
horsebird
Dec 18, 2011 10:44 AM
wize_n
Oct 10, 2008 06:49 AM
