Both fans don't work
Old May 1, 2008 | 10:31 AM
myrsaccord
Default Both fans don't work
Hi, I am new to this forumand have a question. When the AC is running and in stop and go traffic the temp goes way up, I opened the hood and noticed that both fans are not running. One of the fans whould run if i toutched the blade (can't remember which one) and then even that wouldn't work. Coolant is full and does not leak, and it only overheats when the AC is on in town or idling. I looked through the forum and couldn't seem to find a similar problem, but I did notice that the people here seem to have good advice and are patient with newbies.
My question is when should these fans run? What is the most likely casue of this problem? Is there a specific procedure for troubleshooting? Thank you in advance.
Kip
Old May 1, 2008 | 10:45 AM
00AccordLX5spd's Avatar
Registered User
Default RE: Both fans don't work
Both fans should run when the AC is on. With the car turned off and cold, reach down and try to wiggle the fan from front to back (towards the firewall and away from the firewall). If there is any play in it (if it seems loose) your fan motor is likely out. However there are some more electrical diagnostics you should do before going and replacing the motors. Try the test I told you and get back to us. Then we will let you know the electrical teststo perform to verify the problem
Old May 1, 2008 | 10:57 AM
myrsaccord
Thanks will do.
Old May 1, 2008 | 11:49 AM
The fact that the fan ran when you touched the blade is a strong indication thatthe motoris bad.
Try jumpering the battery directly to the fan motor to verify it works or not. I bet it won't run even when powered directly from the battery.
Old May 1, 2008 | 11:53 AM
Registered User
ORIGINAL: JimBlake
That was my initial thought. But he said both fans were not working, so i thoughtit would be a pretty strong coincidence if both fan motors went out at the same time.
BTW myrsaccord - if you dofind out the fan motor needs replacing, ask on here for a DIY if you need it. I just replaced one a few months ago. It's not hard. The hardest part was getting the stupid splash guard back on the bottom of the car after I was done.
Old May 1, 2008 | 02:10 PM
I didn't have to remove the lower splash guard to get the drivers side fan installed.
Another 'caveman' test would be to hit the motor with the handle of a screwdriver. If the fan turns on, the motor is likely bad.
If you have a volt meter, unplug the connection to each fan, turn on the A/C. Each plug should have 12V at the connector. If they do, the fan motors are bad. If one or both doesn't have power, then there is an electrical problem upstream that you need to diagnose.
Maybe one fan has been out for a while and the other cooled adequately until it wore out.
Old May 1, 2008 | 02:24 PM
Registered User
ORIGINAL: PAhonda
Did you go in from the top?
Of course, I did change mine on my 95 V6. The easiest course of action was to go in through the bottom.There was no access to the bottom of the V6 without removing the splash guard.
Old May 1, 2008 | 02:34 PM
I just had to unbolt the two brackets from the top, and the third bolt on the bottom needed to be loosened. The fan housing has a slotted hole in the bottom, so you don't have to remove the entire bolt.
Old May 1, 2008 | 04:45 PM
Registered User
My V6 had 2 slotted holes in the bottom and a wiring harness that had to be disconnected that was in no way accessible from the top. Stupid V6[:@]Ahhh!!! My wife's dad should have bought her the 4cyl model all those years ago!!!
Old May 1, 2008 | 05:10 PM
falkore24's Avatar
[sm=youreright.gif] .... just remember that when Lucy needs a new 6 turbine flying car ..... get her the 4 and tell her that no woman needs that much power!!! .... yeah right! By then she'll have you so wrapped around her little finger that you'll be waxing it for her!
So not to derail the thread, let me add something that might be useful. The AC fan is most likely the motor. The coolant fan may or may not be. There are a few other things to test there like the coolant temperature sensor and fan switch. I think Desert Honda did a DIY writeup on testing for no fan problems, but I may be wrong.
