Both fans don't work
Old May 1, 2008 | 10:55 PM
deserthonda's Avatar
Default RE: Both fans don't work
I personally did not do a write up,, but there is a link in our DIY section that has a lot of good infos on the matter ... here you go ,,
https://www.hondaaccordforum.com/OVE...m_20999/tm.htm
Old May 2, 2008 | 01:04 PM
myrsaccord
Wow, thank you for all the input. Ok, so I checked the fans again with the car running and the ac on and the driver side fan runs with the ac on and turns off when the ac is off. so I am assuming that that is the condenser fan. the other one does not turn on at all, neither have any play in the blades. I am going to try the "screwdriver" method then test the connections with a voltmeter. I'll get back to you.
Kip
tchestman88
Aug 20, 2013 03:05 PM
dasn25
Jul 16, 2013 04:42 PM
mishakol129
Apr 7, 2013 06:48 AM
americapitalpaul
Jul 17, 2011 01:32 PM
ac398
Feb 15, 2010 11:48 AM
