Both Reverse Lights went out at the same time...
Old Aug 9, 2011 | 07:52 AM
redbullman's Avatar
Default Both Reverse Lights went out at the same time...
I have just put a keyless entry in my 95 accord EX and not only a few days later both reverse lights went out.. I dont understand why.. I tried replacing both the bulbs and that didnt do anything.. I checked all the connections to all of the rear lights and those were all fine.. idk whats wrong..
Old Aug 9, 2011 | 08:45 AM
bigpat's Avatar
Almost A Senior Member
Check in the underhood fusebox for a blown fuse first. Next, use a 12 volt test light at the socket of each light to check for power while shifter is in reverse. There has to be a switch on the shifter linkage/cable to test as well.
Old Aug 10, 2011 | 07:07 AM
redbullman's Avatar
I did check the fuse box and the fuses were fine so i was gona take a multimeter and check all the connections..
jaxaccord
Aug 4, 2011 01:04 AM
amk1990
Dec 23, 2010 08:54 PM
Howard S
Sep 25, 2009 07:21 AM
Bartman
Oct 10, 2007 09:39 AM
oldaccord
Oct 13, 2005 02:56 AM
