Brake and fuel line rust
Old Nov 4, 2014 | 11:05 AM
Eric's Avatar
Default Brake and fuel line rust
Hi, I need to replace both brake and fuel lines due to rust. Anyone know the size of those lines?
Thank you
Old Nov 4, 2014 | 11:08 AM
Your thread has been moved. Please read posting rules about not posting help questions in the DIY section.
Old Nov 4, 2014 | 01:36 PM
Replacing entire line can be challenging w/ only access from a car on jack stands. Many splice new line into the old line, but this may not be an option if the brake lines are bad enough.
I had a truck w/ rotten lines and attempted to replace worst looking section. It failed again soon afterwards at another point. Problem is not only general corrosion (loss of metal), but corrosion pitting (chlorides from salt) which results in pinholes at what seems like sound locations. Cup
Following web site may be helpful for sizes. It appears there are two sizes (4.75mm and 8mm). From memory, the smaller size seems likely for Accords. I could not find any info on brake line size in the factory manuals. Technical Help/How to PDF's
You can buy pre-bent assy from Honda parts, but installation will be the issue.
MessAround
Jan 13, 2014 06:24 PM
curvenut
Dec 23, 2013 01:26 PM
eduard
May 9, 2013 12:11 AM
CarConfused
Sep 10, 2012 02:18 PM
96HondaAccord1
Aug 18, 2010 09:58 PM
