Brake light switch?
Old Sep 23, 2009 | 07:50 PM
bruce960's Avatar
Default Brake light switch?
I have a 98 accord coupe. both of the brake lights went out at the same time. I checked the fuse and it's fine. I blocked the brake pedal and checked power at the brake light bulb wiring in the trunk and no power (bulbs are good).
I pulled the brake light switch under the dash and am trying to check continuity. I don't have a wiring diagram.
I notice the switch doesn't have a physical actuator button or pin? Not sure if it is supposed to have one?
Any suggestions?
Old Sep 24, 2009 | 07:19 AM
I'm pretty sure the switch has a button sticking out towards the arm of the pedal. When the pedal is UP, there's a rubber **** on the pedal arm that presses the switch-button.
ps. this is really a General Tech. question, so I'll move it.
rudeg
Dec 31, 2015 07:23 PM
Rabbit
Sep 14, 2012 02:27 PM
victorywhity
Mar 24, 2011 09:37 PM
jdelgado
Oct 29, 2007 09:49 PM
greaser
Aug 24, 2005 12:01 AM
