Brake pads (napa,advanced,or autozone)
Old Mar 2, 2008 | 06:30 AM
blown alcohol's Avatar
Default Brake pads (napa,advanced,or autozone)
I am looking for OEM quality brake pads for a 01 4 wheel disc accord.
I have not seen a recommendation for OEM replacement pads. Should I just buy honda factory pads. Most of my driving is around town.
I have Napa, advancedauto, and autozone close by. Can I get a quality brake pads at one of these stores?
Old Mar 2, 2008 | 09:04 AM
Default RE: Brake pads (napa,advanced,or autozone)
I've used Autozone pads for several of my cars w/o any problems. No doubt OEM pads are good. Check for online sources if you have time and you may find some good deals on OEM pads.
Old Mar 2, 2008 | 06:14 PM
19Accord97
NAPA is always more expensive.
My uncle works at an auto shop and has told me, only go to Napa if you need a part thats extremely difficult to get to or replace. In other words, they are more expensive but better quality.
Old Mar 2, 2008 | 07:59 PM
drummer1279's Avatar
NAPA sucks, they are overly expensive and thier parts arent any better than what you can get anywhere else. I work at Advance and I use the Wearever semi metallics with no issue, but any OE pad will do you just fine, just make sure you are buying the right pad material that your car calls for.
Old Mar 3, 2008 | 06:46 AM
MikeT's Avatar
I've gone the aftermarket route in this area with not so good results. Usually they end up grinding at the end of a medium to hard stop. I switched back to stock Honda and have NEVER had that happen again. It is one place IMO to spend a little more money and get the good stuff.
RobinsonRicer
Jan 14, 2015 06:29 PM
CDelgado
Jun 3, 2009 10:10 AM
kellysa111
May 8, 2009 11:43 AM
RoKnAzn
Jan 19, 2007 01:56 PM
Hondamatic
Dec 31, 2005 07:29 PM
