BRAKE and TCS indicators are on constantly!
Old Nov 14, 2012 | 07:51 PM
There is a service news article on this......the float in the res gets stuck. Sometimes a light tap with a screw driver will free it...if that does not work then the res will have to come off.
Old Nov 14, 2012 | 07:55 PM
Old Nov 15, 2012 | 06:11 AM
Beginning 2003 the level sensor isn't in the cap any more. It's the electrical plug on the side of the reservoir, a bit towards the back. That's because the reservoir is no longer in the shape of a vertical cylinder. Plug is on the far side in this picture.
Attached Thumbnails BRAKE and TCS indicators are on constantly!-03-brake-master.jpg
Old Nov 15, 2012 | 11:29 AM
Uryupin's Avatar
Is there any inner part of it then? Since it's just an electrical plug, how should I fix it? Do I just get a new sensor?
I'm so confused, first people said that the sensor in the cap, so I were trying to figure out how the hell can it be a sensor even though I was quite sure that sensor is the plug that I took out as I said in the very beginning....
Old Nov 15, 2012 | 04:34 PM
Yeah, that plug is for the sensor. I don't have that car any more, but I never had problem with the sensor & I never had to look at it. I don't know if it's a float or some other kind of device.
Old Nov 15, 2012 | 06:58 PM
Did you click on the link I posted, then go to the 4th post and open the pdf.
I really wish we could post pdf's......or am I that slow?
Attached Thumbnails BRAKE and TCS indicators are on constantly!-brake-light-1.jpg   BRAKE and TCS indicators are on constantly!-brake-light-2.jpg
Old Nov 15, 2012 | 09:20 PM
  #17
Gotta admit I didn't look at that. Thanks, Poorman.
We can post pdf files but the size limit is pretty small. "Go advanced" then click on "Manage Attachments".
Old Nov 15, 2012 | 09:45 PM
  #18
The pdf is too big to post,/attach, I tried.....so I said screw it, a "print screen" version might help...just trying to help
Old Nov 17, 2012 | 01:49 PM
  #19
Uryupin's Avatar
RIght now I'm going to go and tap the tank if that's not gonna help then gotta do drain. Any ideas about best way to do it?
Old Nov 19, 2012 | 02:31 PM
  #20
Uryupin's Avatar
I will try to unmount the tank because nothing else I tried was able to fix the problem!! ((( HOPE I WON'T GET fluid all over the car
