Brakes?
Old Jan 8, 2011 | 02:56 AM
ebarrera661's Avatar
Almost A Senior Member
Default Brakes?
So ever since my engine over haul and axle replacement, I have been getting this weird noise from the passenger side front brakes. Like a squeaking/ creeking noise, it's ANNOYING and only happens when i apply the brakes.. Any one got a clue??
Thanks
Old Jan 8, 2011 | 10:29 AM
Sounds are hard to describe and understand...in words. Based upon what you are describing I'm thinking something in the suspension system-bushings. Of course which one(s) is the hard part.
Old Jan 8, 2011 | 01:32 PM
I'll take a vid of it, it's so loud you can hear it inside the car, and it's not the suspension bro. Idk, it almost sounds like the brake pads it self. Like if they skip, like it rolls then the noise and the wheel turns a little then the sound again..
Old Jan 8, 2011 | 02:20 PM
Old Jan 9, 2011 | 07:50 AM
I went for suspension first ("squeaking/ creeking noise") but your second post and the vid shed more light on the issue/noise. Yes it does sound like something in the brakes-what have you already done/checked?-have you pulled the tire and looked at the brakes. Be sure the slides on the caliper are moving freely, pads are clean and moving in the caliper bracket and inspect the rotor for hard/heat spots.
Old Jan 9, 2011 | 12:42 PM
I will check and then report back. Thanks Poorman
alphaney
Feb 12, 2022 10:14 AM
phantomgrey92
Dec 22, 2015 10:24 PM
ZionsWrath
Jan 25, 2009 11:19 PM
Jcaleno
Apr 3, 2007 10:34 PM
thunder_x
Sep 27, 2006 11:00 PM
