break lamp lights
Old Nov 12, 2008 | 07:49 AM
paulhenrick2k8's Avatar
Default break lamp lights
i have this problem where i see the lights are on on the dashboard that says brake lamp.. i guess one of my bulb on brake lights are busted.. how could i change it? what bulb do i need?
thank!
Old Nov 12, 2008 | 08:16 AM
falkore24's Avatar
Default RE: break lamp lights
You have to find the bulb if that indicator is for bulbs. It might also be for the switch that says if your ebrake is on. For the bulbs and changing procedure, take a look in the manual.
Old Nov 12, 2008 | 09:55 AM
it's not the ebrake.. let me check the manual if it shows how to replace bulb on brake lights. tnx!
Old Nov 12, 2008 | 11:40 AM
cjdm98's Avatar
You either use a 7443,or 1157 bulb(dont remeber)
Old Nov 12, 2008 | 11:43 AM
finch13's Avatar
Have someone apply the brake while you look in back to see which ones are burnt out. Then, take the bulb out and get one with the same number. If it doesn't have a number, ask the auto parts store.
Old Nov 14, 2008 | 05:27 PM
is it easy to remove bulbs? i dont have any exp doing stuffs on a car.
Old Nov 14, 2008 | 05:29 PM
very easy, as Finch said, have someone hit the breaks while you look to see what one it is, then this is the bulb replacement guide
Tail light
2057
Stop light
2057
Back up light
1156
Old Nov 18, 2008 | 02:23 AM
ok. thanks!
moon-doggy
Jun 27, 2013 12:53 PM
bjr001
Apr 2, 2013 08:33 PM
ETH13
Jan 24, 2013 09:51 AM
hondaisreal
Oct 28, 2012 09:01 PM
Jcaleno
Apr 15, 2007 01:26 PM
