No break lights, cant shift from park
Old Jun 27, 2013 | 12:47 PM
moon-doggy's Avatar
Default No break lights, cant shift from park
So heres how i think it all started , got a 92 accord lx from my grandmother yesterday, then i found out i had no running lights or brake lights.
I replaced the horn/stop fuse, turned on the running lights, fuse go boom, inspected the tail lights found that the drivers side trunk lid break light wires had melted together, unpluged the module put in a new fuse running lights work fine.
i rebuilt the module with a new socket new wires, running lamp lights up. still no brake lights. found the root cause of the problem, the breaklight pedal switch was not depress b/c of that blue crayon stopper thing was broken and in the floor, cause the light to stay on over night and all day melted those wire and burnt the fuse. fixed the switch with epoxy and 2 pennys, tested the switch with mutimeter, its fine.
no break lights still, inspected futher,
passenger side tail light sensor green/white wire burnt cleaned it up, tested it with mutimeter have a good connection all across, no break lights
for the moment i give up, any ideas
also can shift from park without using the override
Old Jun 27, 2013 | 12:50 PM
Check to see if the brake pedal stopper is still there.
https://www.hondaaccordforum.com/for...ut-park-51526/
Old Jun 27, 2013 | 12:53 PM
moon-doggy's Avatar
the stopper was missing thats what the pennys were for
rudeg
Dec 31, 2015 07:23 PM
Dr. Drivability
Mar 20, 2014 09:48 AM
Ray Marrujo
Nov 26, 2012 08:01 PM
campervan12000
Jun 15, 2011 07:23 AM
malachi_mez
Sep 15, 2010 07:59 PM
